kinette
Frames number: 1 Duration (s): 0.2 Framerate (fps): 5 Polygons max number: 250000 Actors number: 1 Tags: clotheless static datacube texture mannequin |
kinette-cos
Frames number: 8 Duration (s): 1.6 Framerate (fps): 5 Polygons max number: 250000 Actors number: 1 Tags: flat-shoes ample-dress static datacube texture mannequin |
kinette-jea
Frames number: 8 Duration (s): 1.6 Framerate (fps): 5 Polygons max number: 250000 Actors number: 1 Tags: flat-shoes shirt jean static datacube texture mannequin |
kinette-opt1
Frames number: 8 Duration (s): 1.6 Framerate (fps): 5 Polygons max number: 250000 Actors number: 1 Tags: high-heels tight-long-dress static datacube texture mannequin |
kinette-opt2
Frames number: 8 Duration (s): 1.6 Framerate (fps): 5 Polygons max number: 250000 Actors number: 1 Tags: high-heels legging ample-long-dress static datacube texture mannequin |
kinette-opt3
Frames number: 8 Duration (s): 1.6 Framerate (fps): 5 Polygons max number: 250000 Actors number: 1 Tags: flat-shoes legging skater-dress static datacube texture mannequin |
kinette-sho
Frames number: 8 Duration (s): 1.6 Framerate (fps): 5 Polygons max number: 250000 Actors number: 1 Tags: sneakers t-shirt short static datacube texture mannequin |
kinette-tig
Frames number: 8 Duration (s): 1.6 Framerate (fps): 5 Polygons max number: 250000 Actors number: 1 Tags: tank-top legging static datacube texture mannequin |
