kino-hx![]()
Frames number: 1 Duration (s): 0.1 Framerate (fps): 10 Polygons max number: 250000 Actors number: 1 Tags: clotheless static datacube texture mannequin |
kino-cos-hx![]()
Frames number: 1 Duration (s): 0.1 Framerate (fps): 10 Polygons max number: 250000 Actors number: 1 Tags: flat-shoes suit static datacube texture mannequin |
kino-jea-hx![]()
Frames number: 1 Duration (s): 0.1 Framerate (fps): 10 Polygons max number: 250000 Actors number: 1 Tags: flat-shoes shirt jean static datacube texture mannequin |
kino-opt-hx![]()
Frames number: 1 Duration (s): 0.1 Framerate (fps): 10 Polygons max number: 250000 Actors number: 1 Tags: flat-shoes trenchcoat pants static datacube texture mannequin |
kino-sho-hx![]()
Frames number: 1 Duration (s): 0.2 Framerate (fps): 5 Polygons max number: 250000 Actors number: 1 Tags: sneakers t-shirt short static datacube texture mannequin |
kino-tig-hx![]()
Frames number: 1 Duration (s): 0.1 Framerate (fps): 10 Polygons max number: 250000 Actors number: 1 Tags: tank-top short static datacube texture mannequin |
