You can now download the software we use to generate the CVTs of Kinovis models!
This source code aims to generate CVTs from triangle meshes and point clouds.
The code is made available as is without any warranty; without even the implied warranty of fitness for a particular purpose. The redistribution of the code is not permitted. The code are provided for non-commercial research purposes only. If you use this code or part of it in a publication, you agree to cite one or both the papers in the references.
